Side Lights On An Auris Hybrid
muppet7099
Impossible to change due not being able to get at them any ideas please???
Hello Andy - welcome to Toyota Owners Club.
Topic moved to the Auris club and title edited
Not sure what you mean by "not being able to get them"? please elaborate
I just cant get to them my hands just dont fit no room what so ever I want to up grade them to led has my drl's switch off when I turn my side lights on!!!
As far as I'm aware, the DRL's are supposed to switch off when the side or headlights are switched on. Think the clue is in the title - daylight running lights.
With the passenger-side side light, you are supposed to remove the clip retaining the air cleaner duct, and remove the upper part of the air cleaner duct to allow easier access.
DRLs are meant to be bright enough to be seen during the day & therefore too bright (dazzle for other road users) for use at night. As such they are meant to switch off or dim when you switch on your lights.
its the really small ones at the bottom cluster I hve tried so many ways to get them that is impossible the manual page 442 says reach and anti clockwise to release I would do if I could get in the hybrid engine is so compact its unreal....
I had to undo the the rad plastic cover held in by 10mm and pop clips to do mine once that's loose you can move it up and slip an arm down to get to them not an easy job lol
