Where Should I Buy The Parts From...
scraprat
Hi guys just wanted your advice as to where I should buy the parts from for the fault codes P1135 and P1155?
I have several choices I have a local parts supplier I trust, I can try the internet but id like members advice of who they've used or I can bite the bullet and go to my local Toyota dealer.
All help and advice welcome...
I would buy the denso ones with the correct plugs fitted, whether you can get them locally or online doesn't matter just search for best price. But I believe these are the direct replacement and seem better than the cheaper ones around, around the £75-£90 mark each.
That's what I would do if it helps.
I've got a petrol 2.0 51 plate and just had the P1135 on mine, I got the bank1 / sensor 1 sensor from here:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=261220437815&ssPageName=ADME:L:OU:GB:3160
£83 with free p&p its a Denso one with the correct plug. I'm guessing if you search that the same eBay co. they do the other sensor as well for the same price.
I had a few issues afterwards but they weren't to do with the new sensor.
............ Or you could see if Mr Kingo can better that price !
Don't forget you'll need to get the fault light reset afterwards. I did mine with a £20 D900 CanScan reader from eBay.
HTH
Norm
