Brake Warning Lights 2014
Mark Rose
Got a hybrid tend only three weks old already been back to dealer for 3 brake waring lights comming on then go off day later they couldn't find a fault
now they are back on again.
back to the dealer again not happy when only three weeks old
Mark
What lights are they? and when do they come on?
they are 3 orange lights all on right side
ABS
Brake waring and ansti slip
they just come on when normal driving
Please clarify what car you have. Your profile is showing you have a 2011 Prius, and you have posted in the Yaris club. Should you original post read "Got a Yaris Hybrid Trend... "??
Sorry got a a prius wqhich is mine and its the wifes car which is a yaris hybrid trend 2014 14 plate
Mark
ABS
Its strange, when these lights come on there should be a fault code set which the dealer can follow to diagnose, are the dealers saying there is no fault code?
Do they just flash, or are they on for miles?
If 3 come on together and on the same side suggests a poor connection since the car is new, maybe a plug not fully fitted, a 'dry' joint or an earth wire not doing it's job...................as previously mentioned has the car been checked for any fault codes?
Regards Mike169
Hi they are on the same side of the dash.they come on and stay on until restarted. sometimes they are still on after a few restarts then drive a few miles restart and they go off
its werid
The dealer said they couldn't find a fault even though it had a fault code they just reset it and said it will be fine.
need to book back into dealer again but its the inconvenence as the wife has to take a day off work to take it in as shes works miles away
mark
I had a similar problem with a Lexus CT.
It turned out to be a fuse-holder that had been incorrectly fitted during manufacture.
Have a look in the appropriate fuse box and check that one is not loose and all the holders are in a straight line.
I agree with Martin above and re my earlier post, i think you have a production fault, a loose wire, a terminal block not fully fitted, or Martins suggestion a fault at the fuse box, now finding it, which is the dealers problem not yours, let us know how you get on and i suggest you insist on a demo car or something until they have had your car for a few days and are happy with it.
Mike.
