Fault Codes
SFV
Hi All
I have a colleague at work with a 51 plate RAV4 (petrol) that he is very happy with, but now the engine management light is on, and according to a Toyota dealer, the following error codes are causing this:
P0420 Cat System Efficiency
P0430 Below Threshold (Bank 1)
P1155
A/F Sensor Heater Circuit (Bank 2 Sensor 1)
The dealer quoted him £1500 to repair this !!!
Does anybody know if there is an easy fix to this - the car is located in the Gatwick area ?
Would really appreciate any help as my colleague is semi retired and that is a lot of money for him.
P1155 is simply a heater fault on the relevant Lambda sensor (air / fuel sensor). Simply a replacement unit required - £100 in round numbers. The other two codes essentially mean that the catalytic converter on bank 1 cylinders isn't as efficient as it should be in terms of emissions control. I'm assuming that the high price quoted included a new cat to remedy this problem. However, there are reasons that the codes can be spurious / temporary. After replacing the Lambda sensor - reset the engine light and take the car for a lively drive to get the cat nice and hot and you might find that the fault doesn't repeat. If the worse comes to the worse - the cat can be replaced far cheaper than quoted.
Thanks. I will pass on the message to my colleague !
Will advise him to have the sensor replaced and see what happens from there - many thanks again !
