Coilovers
garry auris d4d
hi guys just been in touch with gt4 play trying to source a set coilovers for my 57 plate auris 2.0 d4d tr there telling me that bc don't list any for this model but list for Toyota auris zre152h nze15th 07+ does anyone know if these would fit this model or if any other company make for this model what you guys using on you models?
I was told they didn't list any for my car either, but they could modify a set from the Avensis and change the front spring weight to a 7kg (rather than a 6 which is too soft or an 8 which is track-stiff).
thanks but sounds like lot hassel must be some company that does coilovers for a 57 plate auris d4d
It's not actually any hassle for you Garry, the guy I spoke to said they'd be quite happy to change the spring rate & most of the fitting points are the same anyway.
ok thanks uncle buck but still not sure think I would rather have set that's designed for car not modified to fit
