2005 Toyota Avensis Rear Light Bulb Holder
Billy214
Need help on replacing my bulbs in the correct location. The bulb holder was taken out and 3 bulbs were broken. My friend helped me and took out the other side to see where each bulb is located, i,e brake, turn signal, reverse, parking light.
However he removed them and now we don't know the correct placement. Any have the correct bulb location on the bulb holder for this 2005 Toyota Avensis?
Been looking for the manual, but not found it yet, so any help much appreciated.
Regards
Bill
Hi Cooper,
We now sorted it out by trial and error, mainly it was the issue of 2 different size bulbls, 24v and a 12v.
The turn signals worked in the rear but were flashing at double the rate, like when a bulb goes out and a change
in resistance, they flash faster.
Put the larger of the 2 bulbs in that location and now works as it should. Thanks for the reply, now we can close this case.
