Should The Passenger Airbag Warning Light Stay On, All The Time?
ShamblesX
Bit confused here as to whether the "ON - adult only" light should stay lit, all the time.
The book of words contradicts itself slightly, in that it says:
Front passenger airbag on-off indicator light
Vehicles without smart entry and start system [that'd be us] - these lights come on when the engine switch is set at the "ON" position. It goes off after several seconds... After a few seconds, the passenger airbags "ON" indicator light will come on when the airbags are turn on (sic).
Further down, we are advised to contact Mr T if any of the following occur:
  • The SRS warning light remains on
I'm confused. Should it be on all the time, or off, when driving?
:bangin:
Yes it will stay on all the time and should you disable the airbag a different light warning that it is off will stay illuminated instead.
The light is a requirement under current EU regulations on new cars
Well bugger me, so we've no problem then.
I appreciate the reply - unaware of these new regs :blush:
