Need Help Determining Where The Ocv Filter Is
Just-cruising
Hi all,
i am the owner of a T25 2.0 Avensis, engine is 1az-fse.
i want to locate the OCV filter in order to check it's condition.
i attached a photo of the area of the OCV, and the 2 bolts that i suspect holding the filter. in the pic the OCV is removed.
would really appreciate if someone could point me to the correct Bolt.
Thanks in advance!
post-139617-0-17911700-1396558705_thumb.
Picture attached
post-45863-0-28906700-1396560369_thumb.p
Hi Devon Aygo,
thanks for the pic! but unfortunately it doesn't help me a lot here.
maybe someone can point me to the right bold hiding the OCV filter?
Thanks.
On the 2zz Celica engine it's behind the bolt beneath the OCV with the head pointing towards the front of the car. So it'll probably be the same.
