Which Engine Oil For A R Reg Rav4?
The Mortgage Man
Dipped the oil in the RAv we bought yesterday: black, sticky and low.
So its time for a service me thinks.
The hand book says 4.1lt but isn't clear about the grade.
I will probably use a cheapo brand for the first change and do it again with a branded oil after a couple of thousand miles.
Anyone recommend a grade??
Cheers
5/30 oil
Really! Is that not the lightest grade for cold climates?
I have five recommendations for you.
Out of this, SYNTEC oils are most recommended for your vehicles. Castrol EDGE, SAE 5W-30 PI*, SL 5W-30 - an advanced proprietary formula that provides performance and protection in extreme conditions such as towing, hauling, high and low temperatures, rapid acceleration and stop and go traffic.
Castrol GTX HIGH MILEAGE, SAE 5W-30 PI*, SL 5W-30 - Castrol GTX high mileage - helps extend the life of your engine.
CASTROL GTX, SAE 5W-30 PI*, SL 5W-30 - `superior sludge protection. CASTROL GTX exceeds demanding high shear and stay-in-grade requirements for viscosity breakdown protection.
CASTROL SYNTEC BLEND, SAE 5W-30 PI*, SL 5W-30 - CASTROL SYNTEC blend - CASTROL SYNTEC blend is specially engineered with proprietary CASTROL GTX technology and CASTROL SYNTEC molecular components to provide superior short?trip protection*.
* 5W30 AND 10W30 ONLY CASTROL SYNTEC, SAE 5W-30 PI*, SL 5W-30 - IN extreme tests, CASTROL SYNTEC 5W-30 maintains maximum horsepower longer than the leading conventional oil.
WAW!
5-30w it is then. I am going to have to read a digest so that I get the correct one. But 5-30w it will be.
Many many thanks.
