I have got a t sport, and I need to replace my two front tyres because they have worn unevenly around the edges.
Does anyone know if there is a way of preventing this?
Also, what are good replacements?
Thanks in advance
which edges, inner, outer, both on same side?
Thanks in advance
It is common for all T-Sport Corolla to wear their tyres like you have just explained my ones are the same!
Nick :thumbsup:
Hi, sounds like your tracking is out. Take the car to the garage and get them to check the tracking - some garages do it for free - in the end if the tracking is out it will only be around £25 to put it right again :thumbsup:
As for tyres don't buy them from anywhere else, before u check out http://www.mytyres.net as they do the cheapest ones around.
Tyres are not designed to wear out on the inner or outer sides, so get your tracking checked!
Nick  :thumbsup:
How worn can it get before it would be considered dangerous?
Also what pressure do people run their tyres at?
If the tyre is getting bald, i'd advise u to change it asap . If a copper pulls you over, they can give you points on your license for having a bald tyre!
