Battery
Gasmater
Hi all
Fitting a new Battery this weekend do i have to reset anything original radio/cd,windows
Thank's in advance
You will just loose your preset radio settings and you windows will probably switch from automatic up/down to manual. I think to set the windows back you just hold the window button down when starting the engine and it sets it back to automatic.
Did mine a few weeks ago as I was getting 5amps on start and then it died.
Hi, if you don't want to loose any settings i am sure if you keep the leads powered up with 2 wires and 4 crocodile clips carefully swopping them about/over so your car always has 12v power you should have less problems ALSO leave the drivers door open and no keys in the car just incase things go wrong.
Mike.
