Prius 2012 Aux Port
Anuka Liyanage
Hello. I bought my Toyota Prius 2012 recently, but I can't locate the AUX port. Is it supposed to be next to the 12v power outlet in the console box? Thank you ;)
Yes.
Well it is on the original Gen3 Prius.
Not sure if it moved for the facelift version.
the Aux socket is in the open space under the 'gear' lever, facing the driver on the 2013 Gen 3
As Barrycoll says the AUX is in the cubby below the shift lever, however do you have a pre facelift with HDD nav or post facelift with Touch and Go Nav?
I have the standard OEM Radio. However, 'DISC-AUX' is one button. Can someone be kind enough to upload a picture with AUX port's location? Thank you
The other place to look for the AUX plug is the top left hand side of the upper glove box.
Should be just under the USB port in the centre console box
It's inside the centre control box right at the bottom of the front panel. Well at least it's in my 2012 facelift prius t4 (UK).
It's not by the 12v socket under the gear lever like the pre-facelift model.
As you're in Sri Lanka, your audio equipment may have a different specification to those for the UK market. If in doubt, either ask your dealer, or ask your importer (Toyota Lanka) - http://www.toyota.lk
The 12v socket happens to be in the centre console box
Mine is pictured. Guess yours is a non-uk model?
Sent from my iPhone using Toyota OC
Here is the original gen3 location. Back of the centre console next to the power socket.
post-63313-0-55809200-1397203105_thumb.j
