Noisy Tyres On The Rear - What To Do? Gen 7
KidKoala
Getting tyre buzz on the rear tyres, suspect it is down to uneven wear on the inner edge - outer edge certainly showing signs of this feathering issue.
Are there tyres that don't do this? I don't want to replace them and have the same issue in a few thousand miles time.
Are the tyre pressures correct as a few psi less than required can cause this..
