Hi, had a clutch fitted Tuesday, yesterday noticed the turbo not cutting in, garage can't find the problem, OBD showing no codes. Can anyone help please.
Mass air flow meter sounds a possible cause.
A common diesel fault which sets ecu to safe mode.
At around 40-80 quid off eBay its a cheaper place to start than a new turbo.........
Thank you for reply, had a new turbo 2 years ago, maybe just bad luck went in for clutch came out with no turbo, running fine as I drove it back to garage just completely gutless.
  • 4 weeks later...
Does the engine make a loud HOWLING noise when you change gear. About 1 second duration. Can also happen when you blip the throttle when stationary
