Oe Stereo Output
shellyvvti
Hi all.
Does anyone know if there is a output that I can connect my iPhone to on the original Sony stereo? If this involves buying a lead or something any info would be great!!
Thanks in advance Jon.
There were several head units installed into the Celica so getting an adapter is confusing but do-able.
The head unit has a code on the facia. Do a Google search quoting that and 'mp3 adapter' or similar. You will come up with a result. Connects2 Grom and Yatour manufacture units one will be compatible. Another thing is you must be sure of the size of the Cd changer plugs on the rear. They are generally referred to as 'large toyota 5+7' (old) or small toyota 6+6 (new). You need to remove the head unit to be certain.
There's loads of videos on YouTube as well.
