High Lift Cams
mike j heyworth
Hi I have a 140 vvit 04 celica and I was wondering where I can buy high lift cames for it?? And what are the differebt stages?? Can anyone help thanks.
Not worth it. If you had a 190, then I'd say do it but you'd also need an aftermarket ECU to make full use of the gains.
Both the 140 & 190 are built & tuned very well from Toyota. Any small mods you make, will have very minor power gains. If you want more power, you need to either buy a more powerful car or going force injection.
Check out monkey wrench racing. It's over in the states so if you want them you will have to pay customs charges to import them.
Not worth if for the price and the error codes you will get showing up from fitting them
