2001 Yaris O2 Sensor - Which One To Choose
Ignator
Hello everyone!
First of all, sorry for my english, which probably is not quite polished.
One of the oxygen sensors (after the cat) in my 2001 made-in-France Yaris died recently.
OBD scanning revealed the P0139 error code - oxygen sensor circuit slow response (bank1 sensor2).
The o2 sensor voltage in the "live data" tab in the OBD scanning software was frozen at 0,430V.
I have tested the sensor manually with a multimeter and now I'm sure that it needs to be replaced.
I checked the part number on toyodiy.com, here is the link to my car parts list:
http://www.toyodiy.com/parts/p_E_2001_TOYOTA_YARIS_SCP10L-CGMGKW_8401.html
The OEM sensor for my car is Bosch for about £80 and for me it's quite expensive. I couldn't find any cheaper parts with the exact reference number. However, there is quite a selection of cheap substitutes & used Denso OEM sensors for the Japan built version of the Yaris, here are the reference numbers: http://www.toyodiy.com/parts/p_E_2001_TOYOTA_YARIS_SCP10L-AGMNKW_8401.html
So, (finally :)), my question is: will the sensor from the japanese version work fine with the french version?
I will appreciate any information, regarding the topic :)
