1990 Cabrio 4Ws And Abs Light Help Please
greg12
Hi all,4ws light came on the other day,4ws stopped working,car turns like a bus in a county lane!,I got a new passenger side front hub sensor but when I emoved the old one (3 hours to extract!!) the abs light also came on,fitted new sensor,4ws works!! however both abs and 4ws lights still on,took Battery terminal off for 30 mins replaced it to see if that removed the lights still got the 2 lights,any advice would be great,the lights are annoying and the abs is an MOT fail,thanks greg
post-105683-0-88046200-1398505321_thumb.
just an update in case anyone else getst his trouble,the sensor i bought on the famous auction site for 13 quid is slightly larger than the hole it needs to fit in,(its a camry sensor) therefore the sensor is a few mm away from the teethed ring that actuates the 4ws/abs you will have to pare/sand down body of sensor to fit, ive now done this,both lights out 4ws working great,toyota want about £140.00 for an original sensor so even with this faffing around it was worth it,and for anybody else this is now a cheap easy job......
