2002 Vvtli Driver Side Engine Mount Bolt Thread Size?
SportyDog
Hi all,
First off I've searched the Forum and cannot find anything related to what I need help with.
It's come to my attention by noticing a rattling noise coming from the engine compartment directly in front of the drivers seat. Didn't rattle while stationary and engine being idle. The rattling got louder the higher up the gears I went, and when doing 60 - 70mph the rattling was constant. After Inspecting the engine, I've noticed that the engine mount had only 1 bolt holding it on, and somehow worked its way loose, as its completely missing. Haven't found it resting on the under car covers either, hopefully it's work itself out, and not learking in the engine area somewhere.
But I'm hoping someone on here will be able to provide information on what thread size the bolts are used to secure the mount down, so I can source a replacement ASAP?
I've attached a photo for reference. (Photo sourced from Google, but the same engine layout as mine)
Or alternatively take a trip over to a Toyota dealership to order one.
Many thanks in advance
It will be quicker to get one from Toyota. If you order it Monday it will be available Wednesday AM. Is the missing bolt identical to one on one of the other engine mounts? You might be able to swap them around to stop the noise at least until the replacement arrives.
