European Travel (France) - Headlamp Converter On Toyota Avensis 1.8V-M
Bibsta
European Travel (France) - Headlamp Converter On Toyota Avensis 1.8V-Matic 2010 Saloon (sorry about incomplete topic)
I posted a question about spare bulb kit for use in France, this was resolved so thanks for advice.
I have bought a headlight beam deflector but the guy at the Toyota Dealership suggested that I check if my car has angled or flat beams - how do I check this (apart from the obvious to shine the headlights against a wall) to check if I need these converters or not.
I was told that if I apply the headlamp converters on the wrong type of headlamp then this could cause a problem.
What type of headlamp is fitted to this model year and will it need the converters or not?
Any thoughts would be appreciated.
Thanks,
John
The only way to check them and have the deflectors fitted correctly is to use a headlamp beam setter, pop into your local MOT tester or Toyota dealer and ask them to fit/show where the deflectors should be fitted.
