Handbrake Cover
Moffmo
Well, if ya know let me know how its done, becuase my brother said i can have his handbrake cover whhheee, and i want to put in on, but have to take old one off so.....:)
Cheers Big ears
centre console removed, its clipped on underneith and just pull it off.
!Removed! hell, Fast reply
How do ya take centre console of, do i just unscrew that screw underneath that bit of carpet in the hole? and then pull or... what?
Cheers
Yeh unscrew at the back! I have got my gear gaiter so il need this info too! What do you do afta taking the screw out jaxx??
Although you will probs need a drill with a positive head in to unscrew it, coz mine wudnt budge with a normal screwdriver! So i beta get the drill down
how do you actually take hard plastic off the stick? do i have to literally destroy it??
cheers
hi
at the rear cup holder, u will find a screw.
ONce unscrewed, lift the whole panel off, becareful, i almost snapped the white clips at the front.
i cut the handle off, then fitted a gaitor and a alu handle.
sweet
is there no other way than cutting it?
what if it does fit :blink:
LOL
It should do tho
Matt
hmm in TS it just sort of unlips from itself
obviously different on other models
well the gaiter just pulls away and falls off on mine
maybe its broke!
Im on about the handle, not the gaitor....
The plastic thing stuck to the metal shaft...
LOL
Mattt
ill get me coat........
dunno never took the handle off
Mines the same as moffmo, cudnt get the rubbery/plastic grip off the actual handbrake!
so u want to change it, then obviously you dont like the OEM handle.
cut it, like i did
when u come to sell the car, u will have to give the handle away with the car or soemthng
just lob the old handle over the neighbours fence.......
Done it.
I was hacking away at it when my neighbour cam along and sed what ya doing now then, i send im TRYING to get this handle off....
Hes liek a 80 year old man and he got in got hold of the handle and started twisting a pulling and it came off!
So Done
Thanks anyway guys!
Matt
top job!
modding pensioners at large! beware ppl!
erm dunno follatec or sommat like that :huh:
My brother got it for his punto and i sed since your not using it give me it.
"I want money" ill give you a tenner at most, i bet you only paid like 15 or 20. No £40 actually!
While were on the subject, where can you get handbrake covers from for the yaris?
I kinda got a silver theme going on inside my car, so i was wondering if could get a handbrake cover to match?
