Toyota Wish 2009 Model
tkng1976
Hi friends
I have a problem with my car. It is an 2009 Toyota wish model, 1.8 automatic.
I encountered 2 occurrence on my car. After jamming at causeway about 1.5 hours, I will drive .
However after driving for 5 min, my gear cannot change while the engine still running.
The car totally cannot moved. After resting for half an hour, it is ok again.
I sent to the service centre and it was mentioned my gear box is ok. They did mentioned one valve that when hot will cut off automatically the transmission ? Anyone can help?
They have helped flush out the dirty engine hot and I have drive 3 hours without stopping with no issue.
They mentioned after the engine o flush, the valve is within Toyota specs.
  • 8 months later...
It seems to be a big problem you need to take to nearby repairing center and get it repaired as soon as possible.
