Air Conditioning Where To Go?
Siray7
The aircon in my Yaris is not working as cold as it should. As the weather is getting warmer. I wanted to know where you would advise The best place to take it , Toyota garage, Kwik fit, ATS, independent etc.. . cheers
Think it depends whether the car is still under warranty, and the costs. I'd be inclined to compare what is covered in any air con service/re-gas and prices first, and then decide.
I have used Kwikfit in the past for aircon with complete success.. (in winter when they do half price deals)
Kwik fit and Halfords both do air con regas for £49, speaking from experience with a Yaris that kept losing air con gas
Don't think that Toyota charge much more than that
Steer away from DIY refills or independents offering just a top up service
A proper air con service involves extracting the existing gas and refilling with the exact quantity of gas AND oil which the system requires
Your local Toyota dealer will do this for approx £50, if it is more expensive, have a deal with them
Kingo :thumbsup:
Yeah, just booked re-gas in with Toyota for £60. Beginning to realise its not necessarily more expensive to have stuff done properly at main dealer. . . and done properly. Cheers for advice
The main thing to here is to make sure the system holds pressure before refilling otherwise you are wasting your time and money, I think you will find a Toyota dealer will do this as standard.
Pete.
