No Charge In Battery Every Morning/hour
Samuel E
hello everyone!
my Yaris has been playing up. yesterday morning, I woke up n got in my car. when I started up the engine there was nothing. it was one or two click that were very slow but that's it. so I jump started it and everything was fine again. I drove around for a full hour to make sure the Battery was fully charged again. I turned of the engine n left it for an hour n came back. and once again there was nothing. the car is a 2002 1 litre model.
any advice?
Is it the original Battery?
Sounds like either the Battery isn't holding it's charge or the alternator isn't charging?
Yeah, my first guess is the Battery needs replacing. Garage should be able to check if for you to make sure.
driving around for an hour wont give it a full charge. I would stick it on charge if you can and then re try and then get Battery and alternator checked
Alex
