Engine Varients
Tom. e
I'vbutot 140 bhp celica with a knackered engine from hydrolocking and am planning on putting a new engine in.
So far I have found that it is a 1zz-fe engine which were in a number of toyota vehicles but just want to make sure I can use them and not going to encounter issues along the way!
So I have the possibility of using an avensis engine with engine code E1Z-T72 but I believe this has smaller valves and different rods? Possible a different housing for the drive shaft bearing as well?
So my question is, is this true, will it fit with ancilleries from the celica?
If not what other donor vehicle can I use to increase the search field for possible engines?
Many thank in advance!
