Rav4.2 Front Caliper Carriers
rpaterson
Hi folks. I need to source a carrier so I've got two questions;
1) Are they 'handed' or do they fit either side?
2) Do any other Toyota's share the carrier?
Ta much :)
The calliper mounting has the same part number LH and RH. I'm sure the mounting will be fitted to other models with the same diameter and thickness brake disc but you'd need to check with Toyota which models are covered. The part number for your vehicle is 47721-42040
That's brilliant, thanks very much for the info. I thought it'd be the same part number for LH and RH, but I had no idea what tha number would be!
