2014 Hybrid Speed Sensor Wire
Mark Rose
Wife wants a digital spedo like she had in the civic
tried a couple of GPS ones and they were rubbish also trieed EBD2 port and they flatton Battery
so found one that connects to 12v switched and the speed sensor wire
any body have a diagram where to find the speed sensor wire and 12v switched without removing large parts of the dash
Mark
Not sure of where that wire is but have you considered one of the "SNOOPER" speed camera detection devices which display a digital speed image provided by GPS and are extremely accurate?
A good idea, and as you say they are very accurate, but not that instant, meaning that you could accelerate over the desired speed before it shows up. You could get a scanguage, which would be better especially if you fancy a bit of hypermiling.
David
Tried the GPS not quick enough and pain having to wait for satelites found one called speedview but need to find the vehicle speed sennsor wire does anybody know where i can get a wiring diagram?
Mark
The output for vss (vehicle speed sensor) is located under the dashboard on the left hand side, close to the left front speaker.
To get access to it you have to take out the left ventilation outlet, take down and remove the A-post side panel (remember to pull it out from the top and use a plier to take out the plastic fixing to the post) Then loosen the 10mm screw by the speaker and pull the dashboard up appr. 15 cm at the left side (it's easier if you take out the radio frame because the dashboard is connected to it)
You will find a 22 pin contact in front of the speaker and on terminal 18 is the violet wire you need to get the signal.
Thank you for that sounds a bit to big of a job for me
MArk
