Whining Cvt Gearbox
Grumpy Cabbie
The CVT boxes are service exchange, so I doubt we would ever know the root cause as they are not stripped at dealer level
I'm sure you are right, however if I had a CVT failure I would insist on detailed feedback of "root cause" and a review of how many failures Toyota had experienced of this type, plus a letter to explain the modifications (if any) were made to prevent re occurance, especially if I had to pay £4000 for the replacement !
Just my view !
Car has since been involved in a smash and is being repaired. Upon completion the car is to have the noise investigated. It's getting worse now and drones all the time after the first 5 miles. They either sort it or the car gets chopped in for something other than a Toyota.
  • 2 years later...
My CVT makes a noise when cold, stationary and in gear, (at least I thinks it's the CVT!)
any ideas?
  • 1 year later...
I also have a issue with my iq i often hear a whinning noise but i cant fully agree its coming from. The ctv gear box as when i switch it to neutral the whinning will still be heard and if im not mistaken when you switch to neutral the gearbox will be disengaged .
i think its coming from the alternator .
some one can help
thanks
I cured this issue. It turned out to be an engine mount. Replaced with original Toyota part and all is well.
which engine mount may I ask as they have 2
thanks for your help
