Dashcam Installation
zkab
I am going to install a Dashcam - Blackvue DR500GW/HD - in my RAV4 2011.
For that purpose I need to connect 2 wires to the fusebox:
1) Yellow wire is connected to a permanent positive12 volt supply.
2) White wire is connected to a switched positive 12 volt supply, a supply that comes on when you turn on the ignition key
and goes off when you take it out.
To which fusebox & fuse should I connect these wires without jeopardize the safety of the car.
Hi zkab,Think I would go with the easy option yellow to Battery with inline fuse and white to the back of the ciggie lighter
Del
Thanks for your answer.
Does that mean I have to cut the wire to the ciggie lighter and connect white there ?
I'm going to go for a far cheaper option and the reviews are good (that I have found).
Unlike the Blackvue, I want a in car dvr which is small enough to install and forget and not have to remove it from the car. For a extra £20, there is a hard wire kit so that it does not take up one a cigarette light socket.
I've just not got off my butt and bought one yet !!!
