Yaris 1.0 1999-2005 Engine Specs?
YarisFan5
Hi just wondering whether anyone has any accurate data / information on the 1999 - 2005 model 1.0l Yaris engine? Also, does anyone know whether the engine spec of Japanese built cars is different to those that were built in France? Are all the gearbox ratios the same for this model?
Any help would be greatly appreciated,
AFAIK, gearbox ratios are the same, engines mostly the same mechanically but have slightly different electronics, but I don't know for sure.
The French built car has a different crankshaft sensor.. If you search the forum , there is a fix to make it work...
