Avensis Vermont Passenger Wing 2001
Pavlosaegina
Hi all, after a slight prang I've bought a 2nd hand passenger wing replacement. Anyone know the replacement procedure?
I have not replaced my wing yet - I damaged it last year, but repaired it myself with wood and a 'G' clamp. I am looking for a wing in 6P3 green (1997-2000).
Now looking at wings on offer on the eBay site, the bolt holes tell me what needs to be removed for access. Use the replacement wing as a guide.
Remove the front indicator light. Then undo the clips holding the wheel arch liner. Remove some of the bolts to bumper and part of the under tray, to get access to the bolts behind the bumper to the wing. You don't need to remove the bumper completely, just pull it back. Remove the side indicator light.
After you have done the above, you should be able to remove all the hidden bolts holding the wing. I would remove the top engine bay bolts last.
