Automatic Transmission Problem
Adrian D
hello!
i have a 2006 avensis wit automatic transmission - 4 gears.
i have a problem started few days ago, when i am at about 30-40km'h and i step it a bit harder, i feel a shake from the gear box and the car doesn't accelerate and then suddenly it goes.
if i gentle accelerate, this doesn't happen.
if i kick down it, i feel a small gap in acceleration...
can you help me what to do or if someone faced this issue in the past?
thank you!
Adrian
Could be as simple as low autotransmission fluid level.
Hi!
Problem solved at Toyota service.
It was the ignition coil on the 2nd cylinder. Thanks God that the gearbox is fine!
Best
A
