Clutch Options 2005 2.2 D4D Tspirit
griff01
Hi, here's my juncture. I have a 2005 2.2 D4D avensis with 278000 miles on the original clutch! however it has just started signs of slippage. I obviously need to change it out soon but want to know my options, I.E going for a SMF over a dualmass flywheel or even keep the original flywheel and just change the clutch kit.
Cheers Wayne.
Hello Wayne,
at that mileage I would change the complete clutch and DMF after all it's served you well for 280,000 miles. An SMF is an alternative but it can put extra stress on a gearbox and as yours is high mileage then you may get problem later, just get a decent replacement either from Toyota or something like a LUK.
Regards,
Pete.
wow that's good going! I would stick with dmf, On the genuine clutches it has LuK stamped on it. I hope you can see in the picture I have attached.
any advice on to keep a clutch going that long? is the mileage motorway runs?
post-125194-0-14002000-1399737212_thumb.
  • 4 weeks later...
I've got the same car but at 122 k and got the flywheel and clutch done at the same time but for a solid state. It's now much louder then before and I don't know if it's just the flywheel or something else. Can anyone help.
I think Wayne youre better off with a DMF.
Chirs
