Toyota Iq Headlight Dissasembly
kai3747
excellent job , i will try this :) do you have photos from all tha procedure and some explanation please ??? iam amateur :)
There is some more pictures at the Angel Eyes topic.
David, may be you can find if there is the possibility to use only one inverter.It could be more easy.
Some pictures of the rings from the 2 different sellers
I make a little comparison between my 2 rings by to :
http://www.aliexpress.com/snapshot/6132914018.html named on the pictures A
and the 4 rings buy to
http://www.aliexpress.com/snapshot/6133000393.html named on the pictures seller B
A are a bit more shine and a bit bigger.
The back of A and B are a bit different. It is a bit more is to fix B with glue than A (see picture)
Enjoy youe installation. All commentary are welcome
post-118843-0-82720200-1405181567_thumb.
post-118843-0-88566800-1405181568_thumb.
post-118843-0-60584900-1405181570_thumb.
post-118843-0-22676100-1405181573_thumb.
post-118843-0-74920500-1405181574_thumb.
post-118843-0-59162400-1405181576_thumb.
post-118843-0-64692600-1405181578_thumb.
Thanks Christian
I am sure i can extend the cable
David
Hello David, it could have many avantages to suppress( remove ???) the plugs
Only one inverter, only a small hole to get out the threads out of the beam, and no necessary to drill a hole inside .
David
Your new little job.........................
post-118843-0-15942100-1405242094_thumb.
Bigger for your young eyes................
post-118843-0-95377100-1405242315_thumb.
Ha ha
Usually they don't like you messing around with the secondary side due to possible fatal results
David
David
hello
Did you find a way to extend the wires of the inverters? It is a bit stupid to have to use 2.
Friendly, Christian.
Did anybody has do the same with angel eyes?
Sorry Christian
Have not had time to pursue the headlight project
David
Does anybody has the solution to extend the wires of one inverter?
