New Disks ,pads And Wheel Bearing
cooper12000
ok I have just got back from the garage having taken it there for noise from the front wheel. been told I need a new bearing and disks and pads as the disks are warped. I am kind of shocked at the new disks and pads as I only replaced them a year ago and there is hardly any wear on the disks. I fitted adl bluepoint ones and the garage said they were crap.
what brand do people use on here and has anyone had issues with adl b4.,
also I need to have the bearing replaced... I have agreed with the garage that if I remove the hub they will press it out for me. what is the best way of getting the hub off with minimum effort.
many thanks coop
I am using adl blueprint, first time I have used them on the avensis will see how they go.
What year avensis ? Depending on year is normally easy to replace bearings if you've got a puller to remove old ones. The press in new ones.
Discs & pads would be both sides too.
Are they binding ? Cheap pads can stick on a disc has the disc been worn more on the inner edge?
Never had a problem with my discs think mine was Delphi when I replaced. Blueprint is another common. Others use mintex only ;)
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
