Breaking A Modified T-Sport
Escy
This is the advert from when I bought it. Engine and gearbox aren't available http://www.ebay.co.uk/itm/251502366099?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Rota Grid 17" alloys. Good condition, couple of marks on them but as they are satin black they are easily touched up. The tyres are 215/40/17 Yokohama Parada Spec II, 2 are 6mm 2 are 4mm so loads of life in them. The alloys are ET45 - £500.
Eibach 25mm bolt on spacers - £45
2ZZ head with valves - £125
New chain - £25
New 2ZZ oil pump made by Aisin £45
Alternator - £25
T-Sport grill - £40
BC Racing Type BR coilovers, good condition, threads have been copper greased so the adjusters should be free. No knocks and clunks when on the car, no leaks. The damping and front top mounts adjustable. There are some brand new drop links fitted (these were done for the MOT a couple of weeks back). These are £750 new. £375
Cusco Strut brace, has the odd scuff/scratch, should polish up fine - £75
Refurbished front brakes calipers, still have the zinc plating on them, the inside of the pistons are like new, no surface rust or anything. Seals are perfect. - £50
Black Diamond Predator brake pads and grooved discs, both are like brand new, no wear marks or scoring at all. - £50
I'll post. Can even post bigger things like the bonnet, doors and boot lid. I use Paisley Freight so will go by their prices.
All the body panels are in good condition with nice paint.
Wings £25 each
Bootlid (glass but no spoiler) - £30
Bonnet - £30
Door mirrors £15 each
Rear seats - £35
Parcel shelf - £20
Door cards - £15 each
Door glass - £20 each
All the plastic trims (sills, pillars, foot well, etc) £5 each
Boot trim £5 each
Hi, how much for the instrument cluster posted to NP11 ?
Cheers.
£25 posted for the cluster.
I'm not sure about the Auris, I had a quick look on the BC Racing website, couldn't find part numbers. Maybe it's worth calling them and asking.
If you're only in Newport, you're welcome to come over, I'm in Beddau so not too far away
  • 3 months later...
