Drivers Side Light Panel Replacement 1.8 Vvti 2001
Pavlosaegina
Hi All,
Someone damaged my drivers side rear light panel, the small one that fits under the rear light cluster, & carries the 'Avensis' Badge.
1) Has any one changed one of these & knows the procedure?
2) I believe its rivetted in place - is this true.
3) If it is rivetted, could I replace with plastic clips, or simlar, - any idea of the size of fitting?
