Oil Filter Removal Tool
salloo
Hi Everyone,
Apology if this has already posted, Just wandering whether the following are the right tool for removing oil filter, if yes then which one is better
  1. http://www.amazon.co.uk/Laser-4232-Filter-Wrench-Flutes/dp/B0012M9K2E
  2. http://www.amazon.co.uk/gp/product/B005I4YYUU
  3. http://www.amazon.co.uk/Draper-Expert-Toyota-Filter-Replacement/dp/B008RXS7FM/ref=pd_cp_auto_2
I am asking for Toyota Auris 1.33VVTI 2010. Thanks in Advance
If yours is the paper element type with a screw on plastic/aluminium cover then either 2 or 3 will be fine. They have the cut outs to engage the "lugs" on the cover to reduce the risk of slipping.
I have the Draper version and it fits perfectly. No 1 is a weak pressed steel example and not very strong or durable and at 65mm is too big..
If yours is the older screw on canister type filter then ignore my post!
Thanks mrpj,
Following is the example of mine.
http://teon.co/cars/toyota-auris-petrol-1-dot-33-vvt-i/manuals/51b71dfaa11460327500020b/chapters/interim-service/chapter_parts/renew-oil-cartridge
I have already received oil filter and that is just paper element type with couple of rubber rings and a utility part to remove oil. I'll go for 3 which is cheaper amongst 2 and 3.
That's it. :thumbsup:
As I mentioned, the middle of the three slots on each side of the tool locate on the two ears/lugs on the cover, one of which is visible in your link.
