Hi all,
I have an Aygo Blue 09
I have successsfully paired my phone to the car's bluetooth.
But it does not connect.
I have tried connecting manually with no luck.
Phone's visibility is set to: shown to all.
Also, the car's bluetooth does not flash.
Assuming that the car's bluetooth is faulty is there any way I can get it fixed or replaced.
Thanks.
Thanks for the response.
I have ther standard bluetooth kit that comes with the Aygo Blue, not Tom Tom.
I don't think compatibility is an issue as it pairs the device, but does not connect.
I had issues with this, but then I worked out I had to get my phone to connect by pressing on the device name shown in the bluetooth menu. Not that I use it much now, but I worked it out!
Yep,
I tried letting it connect automatically and selecting TOYOTA from the phone menu.
It definetely paired, but it doesn't connect.
All the menu's work - but there's no flashing blue light when I start up the car and it searches for devices.
I'm pretty sure its packed up.
Can I get a replacement - I don't want to replace the whole stero unit just for bluetooth.
What phone and operating system are you running.
I had this issue when I upgraded my phone I had to remove all the old phones and start again.
Fortunately it them worked perfectly. ;)
I have a plug in tom tom with bluetooth in my car which has never had issues once I discovered the right settings on the phone. Do you have the tom tom unit?
