Meths
Moffmo
You know if you use methathle spirit or whatever to clean ya dash board? does it melt the plastic?? Thats what my mum and dad said, but i dont think they hava clue frankly lol
So Does it?
Cheers :thumbsup:
Don't think so.
But there are specialist dash cleaners available that will do the job better.
If you're still unsure, thin it down with water.
Rich
no, its just that i got alike a switch which has a sticky back and it keeps peeling off with heat, but i reckon cleaning surface with meths to clean checimals and stuff will help it stick better
Cheers
Matt
dunno .. all my Methanol goes into the WI :)
rub it on a bit of the dash you cant see easily first.
It should be fine...as would white spirits...to remove grease...and sticky residues etc....but as mentioned if even unsure...test on a hidden area.
Vipes
Meths should be fine and certainly removes glue, etc. effectively but as Viper 7 already said, test on an unseen area first. Also have a damp sponge ready to clean the area straight after to remove any residue and then wipe over with a dry cloth.
Meths leaves a residue due to the colouring in it. Clear IMS (Industrial meths) is better if you can get it but wiping off with a just damp sponge is the best way to go.
