Wheel Rattle
pedro7680
why does it all go wrong at the one time.
my front off side wheel is ratting very noisily at slow speeds.
the car still steers ok, is fine at normal speeds,
but when slow this rattle, its a metallicy clanking, is blatently heard!
wondering clutch? brakes related?. bearing?
going to get the wheel off at the weekend. but any fore warnings are appreciated.
jack IT UP AT THE WHEEL IN QUESTION- ENGAGE FIRST GEAR LET CLUTCH OUT AND GET OUT AND LISTEN.MINE WAS THE STONE GUARD HAD ROTTEN AND DROPPED IN BRAKE DISCS A LITTLE WAY.
the split in the brake disc some times gets small stone chippings stuck in them which rattle like hell when at slow speeds. jack up car and remove wheel turn brake disc by hand and check the slots in disc. happens to me all the time.
sounds like the clips that hold the calipers are loose and cause the pads of have play within them...
cheers lads, great advice,
ill do them all on saturday morning
