2C-Te Efi Fuse Blown
Metaripley
Hello,
I own a 2000 avansis with 2C-TE engine.
While driving the engine stalled and the efi fuse was blown.
I have switched the relay, unplugged every plug I could find from the engine loom that's connected to the fuel pump thingy, and the 4 on top of the engine.
Then i put a new fuse in and when i put the ignition to "on" the light for the glow plugs comes on for a second and then the fuse blows again. Or is blows intermediately.
So I think its a short in the engine wiring loom.
I am not familiar with diesel engines so I have no Idea what everything is or exactly does.
SO maybe someone has a wiing diagram for me so i can track the EFI circuit.
Or have other opinions about the cause of this problem?
Never mind.
I found the problem.
At top of the engine there is the main loom. This is supposed to be hold in place with 3 clips.
2 of them where gone and "fixed" by a previous owner or so.
They where fixed with a tyraps. So the metal behind grinned trough to the copper wire.
