Anyone Done The 5 Speed To 6 Speed Gearbox Change? I Need Advice
scots1
As header says...anyone done a 5 to 6 speed gearbox change coz i need advice urgently
IMG 20140526 00060
As u can see...selectors are at front of the Celica 6 speed box rather than the 5 speed avensis one which is located at rear>>>>>
Somebody did do a conversion on the forum a long time ago, but I cannot find the post.
I think that everything fits, but you may or need the longer selector cables if the Avensis cables cannot reach.
From what i remember, the person who did that project stated that the gear ratios were slightly lower than 5 speed, with 6th being slightly higher. So you had a slight reduction of rpm at motorway speeds.
I did some research and if the info are correct, the topgear ratios are the same for both gearboxes! See the following attachments.
http://www.cars-data.com/en/toyota-celica-1.8-vvt-i-specs/48071
http://www.cars-data.com/en/toyota-avensis-1.8-16v-vvt-i-linea-sol-specs/47519
Basically it is a close ratio gearbox due to a lower final drive ratio.
Hopefully the speedo will read the same as before.
As I said in your other post, I would stick to the original gearbox.
Good luck what ever you do.
Thats it all done - no crap unreliable 5 speed gearbox anymore :-)
.... a bit of a bugger to do but driving it after it was done was the reward.
What a difference it has made overall to power, and even quietened engine down too having that extra gear..... i'd advise anyone to do it.... :-)
