Srs Airbag Warning Light ?
muddymanuk
Hi all,
Yesterday I changed the front and rear discs & pads n my 2005 avensis t25 estate, whilst taking it for a short spin afterwards I did an emergency stop to ensure the new brakes were OK and not pulling to one side, everything was good. This morning I noticed the srs warning light was flashing, could this be because of the emergency stop ?
If there is a fault can the fault codes be read manually or do l need to have them read at a garage at some rip off price?
Also is there a common reason why this may happen ?
Regards,
Nick.
ps, I've also read suggestions of disconnecting the Battery for a short while, however the last time l had to do that it clears the ECU memory and my fuel consumption was lousy until the memory was rebuilt over about 1500 miles !
I will also check under the seats to ensure the electrics weren't dislodged when doing the emergency stop as l have a sub woofer under there which rolls around a little !
Nick.
SRS should be the supplemental restraint system (or something like that) so I'd be looking for an airbag plug loose or something rather than anything to do with ABS.
