Engine Management Light
Cannonc
Hi all, just a quick question. Should the engine management light come on briefly on start up on a 2004 Avensis. Mine doesn't!!!
Cannonc
it should come on when the ignition is turned on then go off when engine is started.
is yours petrol or diesel.
fast foward to 0.51 secs- mines similar to this
It should only come up and then go away after ignition.
Mine is 1.8 petrol T4, but the light doesn't come on at all. The bulb must have been removed!!
