Tow Bar
iiyama
Will a tow bar from a '54 plate three door fit an '07 five door with no spare on the rear door?
HI Ian a quick check shows that the answer is no as different No's are shown from 2006 on a couple suppliers online
Del
Thanks. Wasn't entierly sure but it would have saved a bit of money if it had. Bar on the older car is a genuine Toyota detachable item and the area under the newer car looks to be the same, however the bumper is quite a lot different and may need trimming. Couldn't offer the bar up as its still fitted to the three door.
