Wheel Options - What Will Fit?
maiden
Hi
What wheel options do I have for my 2001 Celica?
I know a lot of the time many other models int he manufacturers range fit other cars, some even from different brands if the pcd etc is correct.
Any advice?
Does this link help, Helen?.
http://www.carlsalter.com/all-wheel-fitments.html
The most common 5x100 rim from other models is the Mk4 Golf. Be careful with Impreza rims though, they have a high ET/Offset, so sit inboard of the wheel arches.
You may also need a different type of wheel nut, depending on the replacement rims, plus spigot rings too.
