Hi everyone i have a 2013 Verso Icon with the bluetooth/DAB system (not sure of its name!) but no sat nav (£650 for that - nah you're ok!) can i get this system upgraded as surely there must be a software upgrade by now? It does have usb. Any ideas pls? :disgust:
The main issue is that it doesn't sync my contacts as it stops at 1000 and i have more than that. Any help?
This was a common (early) complaint with the head unit fitted to the Prius. It has a 1000 contact limit. Fine for the average geek with two friends and a mother, not so great for business users. I'm surprised it's still an issue to be honest, think Toyota dropped off a bit there. I don't know any any solution I'm afraid, apart from trimming your contacts list...which is probably not a solution at all!
Any way of doing an update?
Checking on Toyota's technical site there are no updates for non nav equipped cars.
Thanks to you but no thanks to Toyota :(
