Hi, I have had my aygo for a year now and had no problems however recently it has started cutting out. It will be running fine however all of a sudden the engine starts to die and if even if I increase the revs it still happens. Any ideas? Thanks
Not enough electrical power getting to it
It starts and runs fine however as it gets warmer this is when the problem is occurring more often. Would this be due to electrical power?
Battery I think or over heat as you say that when temperature is increased maybe?
It could be, push all your connectors together and retighten any earth leads and check for any signs of abrasion on any wires.
Will try that then. Thanks
Fretwells51,
What happened? No feed back? Your feed back helps others so keep in touch.
Yes sorry about not replying. Turned out it was the fuel pump that was on it's last legs. Changed it and run right straight away
