Avensis T4 2011 Model
peustace
I've been driving a 00 1.4 hatchback corolla now for 8 years now and feel its time for an upgrade. I'm looking at a T4 2011 Avensis model - with some extra optionals - leather interior, heated seats, memory adjustable seats (some of the standards from the T Spirit)
Just wanted to see if there's anything I should be conscious of when looking at potential purchases? Any known major issues with this particular model?
Cheers for the help...
Parking brake actuator has been mentioned a few times.
  • 3 years later...
EPB actuator failure seems to be pretty much more of a potential concern than an actual problem i.e. it's very rare.
Another thing to look for is cracking of the paint/skin on the front doors by the restrictor stay - there are some good photos in this forum.
I guess the car isn't a facelift?
The Valvematic petrol engine has a rattle from the vacuum pump - this is normal and there is nothing wrong. The diesels may need EGR checked/cleaned. Any issues will cause caution/warning symbols to appear. The EPB should auto release and later version auto apply when the engine is switched off. The gearbox can be a little tricky when cold, butI have an older '09 petrol and it is fine.
Basically test drive and compare. Read posts on this forum.
Comments will be useful for others but as OP was 3 years ago I hope they've made a decision now!!!
Fooled by the layout/system. I looked from the general forum page which shows the latest post from each of the models/range. if I had looked from within the Avensis - which I normally do, I would have spotted the how old the subject was. Mind you, I agree it is still useful now.
